Sponsored by: CARiD
Overheating (ls1) question
Old Oct 25, 2010 | 05:52 PM
KUTTER's Avatar
Default Overheating (ls1) question
Friend of mines been having an odd overheating issue, on his 99 camaro. It seems to only overheat when he is on the highway, and nothing super bad we drove it around yest and went like 15 miles on the highway and it was just approaching the 3rd line (4th is red pretty sure). Anyways when we noticed it we got off to pull off and check fans and such. As we were waiting at light at off ramp, dang car started getting cooler so scratch fans.So we took it to his house driving off highway about another 20-25 miles taking regular roads plenty lights and the car was back at normal.
Get to his house checked to make sure there was no crap cluttering up the air vent at bottom, as Ive read thats sometimes a issue.No blockage, coolant not low,no oil in radiator or milky oil. Anyone have any ideas what would cause this?
Old Oct 25, 2010 | 06:01 PM
msydow's Avatar
thermostat sticking? seems like it only gets hot when the engine is loaded up at highway speeds. thats a usual indication on the stuff i work on. miles on cooling system/ mods on car?
Old Oct 26, 2010 | 08:35 AM
wssix99's Avatar
Save the manuals!
How is your belt? Maybe its slipping and causing the water pump to bog down? You can check the status at the marks on the tensioner.
Old Oct 27, 2010 | 07:01 AM
stang2supra's Avatar
Any issues driving it hard around town?
Old Oct 27, 2010 | 08:57 AM
senicalj4579's Avatar
If the car is really overheating check the t stat and take that radiator right out and clean it good. Maybe even do a home flush and replace with new dexcool.
Its hard to know if its overheating for sure cause you cant go by the gauge they are not accurate. You should check what the pcm says. If the fans come on and the car cools down then I would say there isnt a big problem if any. These engines are made to run hot (at least 190f).
