Sponsored by: CARiD
Lost power plugging a vacuum leak??
Old Nov 23, 2010 | 01:42 AM
MR_M's Avatar
Default Lost power plugging a vacuum leak??
Hey everyone, very confused here. I had been tryin to track down a vacuum leak for a couple of days now. Well, i found it then immediately plugged it up. Idle dropped by a couple hundred rpm as to be expected, all is well. Anyway, i went out on the highway soon afterward to see if there may have been any difference in the way the car ran. There was a difference alright, the car seemed noticeably slower versus having the vacuum leak open. I'm perplexed by this lol, any opinions on the matter?
Old Nov 23, 2010 | 11:30 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Fuel trims may need time to relearn after having supplied extra fuel to cover the leak. You can reset the trims quicker with a battery disconnect, or just let them relearn over time.
Old Nov 23, 2010 | 05:17 PM
MR_M's Avatar
Thanks RPM, i figured that may be what i need to do. I drove immediately after plugging the leak, so i imagine that it didn't have any time to adjust to the change(guess i was too hasty lol). I'll go reset the pcm and take a lil drive.
Old Nov 24, 2010 | 07:48 AM
67RSCamaroVette's Avatar
It's probably running extra rich after "getting used to" the artificial lean condition. Disconnect the battery for 10 minutes, and after 2 or 3 startups and some wheel time, it'll be back to normal. Good luck
Old Dec 2, 2010 | 09:38 PM
O2Form's Avatar
Where was the leak? I have a vacuum leak someplace too but so far havnt found it.
