Sponsored by: CARiD
LT1 wont start
Old Feb 5, 2004 | 07:36 PM
svenh44's Avatar
Angry LT1 wont start
93 Z with 116000 miles started fine when I went to work then would not start after work
New opti, water pump with tune up plugs, wires
When I turn the key all the lights come on, on the dash. no flashing lights.
There is no drag of the battery at all. Starter doesn't make a sound. Doesn't even click. But i can here my fuel pump come on.
Checked fuses battery is fully charged. Could it be the starter or maybe VATS.
Please help out....
Old Feb 5, 2004 | 10:52 PM
mighty mex's Avatar
if it was the VATS your fuel pump would not even turn on.
try banging on the starter a few times. if it starts after you have banged on the starter then most likely its your starter
Old Feb 12, 2004 | 09:04 PM
HOOZNXT's Avatar
I'd say it's the starter. If it were the VATS you'd be getting lights on the dash.
Old Feb 12, 2004 | 11:42 PM
CP30thLT1's Avatar
My buddy had the exact same problem as you, it was his starter. I ditto the above comments.
