Sponsored by: CARiD
LS2 Sparkplug Gapping
Old Jan 10, 2011 | 09:36 AM
Ls2SilverBullet's Avatar
Default LS2 Sparkplug Gapping
I've been wanting to get some iridium plugs for my car and was thinking some NGK tr55ix's or possibly densos. I found several sites saying the gaps from the factory are .060 but also have found one or two that said the stock gap was .040 .
When I went to advanced, autozone, and napa I couldn't find them pregapped at .060, only other random gaps from .035 to .050.
Can anyone shed some light on this?
Thanks,
Eric
Old Jan 10, 2011 | 10:22 PM
So I looked at advanced again today when i was getting some other **** and the computer said .040 for every iridium plug for my car
Old Jan 12, 2011 | 08:34 AM
sjsingle1's Avatar
i use .060 ........i also have the truck coils
Old Jan 12, 2011 | 12:45 PM
What motor 6.0? iron or aluminum? and did you order them online or is that what came up in the system where you bought them?
Old Jan 12, 2011 | 02:49 PM
LS6427's Avatar
Thanks,
Eric
LS1, LS6, LS2, etc.......they are all the same ole V8 engine. There are no special gap sizes for the LSx line of blocks. They are just different blocks and they are every day, regular V8 engines, they are nothing special in the automotive world.
They need nothing special, especially gaps.
Buy either the NGK TR5 or TR55 plugs, they are both identical plugs, they just come gapped differently from the factory.
Buy a gapper and gap them to .050. That gap works perfectly for any LSx engine, whether its bone factory stock or a 600 RWHP N/A big stroker engine.
Unless you have nitrous or forced induction you can't perform better with a .040 or a .060, you will see ZERO difference. I've tried gaps from .035 to .060 when I was stock and with my current 427ci. ZERO difference in performance and/or gas mileage. Engine runs 100% identical throughout the rpm range, at 30 mph and when I do 175 mph runs. Why, because its nothing special, its a normal every day V8. Don't put too much thought into it.
Iridiums....waste of money. They will do nothing that the regular NGK won't do.
Old Jan 12, 2011 | 07:34 PM
I'm aware what exactly a lsx engine is, but I thought that the plug gap could vary depending on the stroke, head setup, and how much fuel is being dumped.
So what would you need to gap a plug for if they will be identical from .035 to .060?
Old Jan 14, 2011 | 02:25 PM
LS6427's Avatar
To me, after having checked all the gaps in that range on both my stock engine and my 427ci.....I chose one near the middle. .050
