Sponsored by: CARiD
sould i be shiting bricks?
Old Feb 10, 2011 | 05:31 PM
stubbs4's Avatar
Default sould i be shiting bricks?
Ok so i have an oil leak now and i haven not been able to get under the car with all this snow But when i turn the car off the engine makes a noise i have nerver heard of before and it shakes a litte like
it sounds like when i took of the lid and bellows off a few months ago any idea what makes this happen
car is 100 stock and the oil leak is very small about 2 table spoons
Old Feb 10, 2011 | 05:39 PM
LS6427's Avatar
Where does that oil look likes it coming from, like what part of the engine is directly above it?
Old Feb 10, 2011 | 05:40 PM
stubbs4's Avatar
some where around the pan i cant tell from where not excatly level but i would say the oil filter or one of the bolts on that side i just replacedthe oil pan 5 mns ago
oil psi is a litte low its off about 10-15 psi for the cold
Old Feb 10, 2011 | 05:56 PM
LS6427's Avatar
Huh....low oil pressure and the car shakes when you shut it down.
Maybe a spun/scored rod bearing. Not that it would cause a leak.......
