Sponsored by: CARiD
Water in Computer PIN connector
Old Feb 16, 2011 | 01:20 PM
AgentLS1Z's Avatar
Default Water in Computer PIN connector
My '02 Z28 has been getting condensation and water build up in the upper Computer pin connector. My mechanic was able to dry it up and clean up some of the black crap that built up due to the water. Unfortunately water built up again and because of this my tach, gas gauge doesnt work and a bunch of lights come on in the dash. There is no evidence of water on the outside of the computer. How can this condensation be forming?
Old Feb 16, 2011 | 02:51 PM
RARON455's Avatar
the seals on that weathertite connector must be bad,or gone.
Old Feb 16, 2011 | 04:59 PM
eseibel67's Avatar
The gasket on the PCM should seal the water out. If the car is sitting on a slight downhill angle, and is sitting with the right slightly lower than the left, a heavy downpour will direct water from the black plastic "eavestrough" at the base of the windshield right into the PCM connector. If the flow is torrential, some water can get past the gasket.
Old Feb 17, 2011 | 08:28 PM
stimpy's Avatar
quit driving your car into the lake ...
