Sponsored by: CARiD
car will not get up to operating temp
Old Mar 5, 2011 | 06:41 PM
shane0328's Avatar
Default car will not get up to operating temp
i have an 1998 camaro ls1, and the temp gauge will not go above about 170, im pretty sure its not the thermostat my car almost overheated one time and it was reading hot then (thank god.) other than that the car runs fine, gas mileage seems reasonable, nothing out of the ordinary exept the engine running cold, so im stumped please help if you know about this or have had this problem before thank you.
Old Mar 5, 2011 | 08:33 PM
RedHotG8's Avatar
It seems like there's a problem with the thermostat to me. Either it's rated too low or it's not functioning properly.
Old Mar 5, 2011 | 08:39 PM
garygnu's Avatar
check the stat.its easy to do.
Old Mar 5, 2011 | 08:44 PM
LS6427's Avatar
If the stat sticks open....you will overheat or run hotter than normal. Unless its stuck open and you're driving on the highway in 10*F weather.
If the stat sticks closed....you will over heat in a hurry and the temp needle will bury into the red in 15 minutes.
These guages are not accurate at all. They are just guides. Maybe your coolant temp sensor is failing or your guage is just showing something different.
Get a scanner on it and see whast the true temp is before you start going nuts chasing a problem.
Old Mar 6, 2011 | 11:40 AM
senicalj4579's Avatar
I would think the t stat is stuck open.
Old Mar 7, 2011 | 06:41 PM
Davey G's Avatar
If the stat is stuck open you will not overheat. However you will never get up to true operating temp unless you sitting in trafficmon a hot day. If it didn't open you'll overheat
Old Mar 7, 2011 | 09:13 PM
LooseMoose's Avatar
it can overheat if it is stuck open because the coolant stays cycling in a hot motor. The thermostat closes to get the coolant to stay in the radiator and cool down. so +1 on what ls6427 said.
Old Mar 7, 2011 | 09:22 PM
RedHotG8's Avatar
You have it backwards, the coolant circulates through the motor AND the radiator when the t-stat is open. When the motor is cold the t-stat closes to keep the coolant in the motor so it warms up faster, then it opens when it gets to operating temp so the coolant can circulate through the radiator to cool it down.
While the thermostat is closed, there is no flow of coolant in the radiator loop, and water flow is instead redirected back through the engine, allowing it to warm up rapidly while also avoiding hotspots within the engine. The thermostat stays closed until the coolant temperature reaches the nominal thermostat opening temperature. The thermostat then progressively opens as the coolant temperature increases to the optimum operating temperature, increasing the coolant flow to the radiator. Once the optimum operating temperature is reached, the thermostat progressively increases or decreases its opening in response to temperature changes, dynamically balancing the coolant recirculation flow and coolant flow to the radiator to maintain the engine temperature in the optimum range as engine heat output, vehicle speed, and outside ambient temperature change.
Old Mar 7, 2011 | 10:25 PM
shane0328's Avatar
well i dont know much about thermostats never had to mess with them but ur saying the thermostat closes and cuts off coolant flow?
Old Mar 7, 2011 | 10:30 PM
shane0328's Avatar
well i dont know much about thermostats never had to mess with them but ur saying the thermostat closes and cuts off coolant flow? and i have had a scanner on it and it has no codes for thermostat or anything like that.
Old Mar 7, 2011 | 10:46 PM
waterbug1999's Avatar
98's are notorious for the temp gage reading low.. I bet if u hook it up to some software ull see its ~205 or so.
Old Mar 7, 2011 | 10:55 PM
RedHotG8's Avatar
Yes it closes when the motor is cold and opens when it gets up to temp. It works mechanically not electronically so the t-stat won't directly throw a code.
Old Mar 7, 2011 | 11:35 PM
wssix99's Avatar
Save the manuals!
bad thermostat - happened to me
Old Mar 7, 2011 | 11:58 PM
shaun's Avatar
easy test let the car run for 10-15 min in your driveway and the put your hand(be carefull) on the radiator or on the top rad hose and see if its cold and if it is the tstat it stuck closed.
Old Mar 8, 2011 | 02:55 PM
wssix99's Avatar
Save the manuals!
The problem here is the T-stat stuck open, right?
Old Mar 8, 2011 | 10:13 PM
LS6427's Avatar
Not a very good test. T-stats can stick partially opened too, letting hot coolant flow and heat these hoses and radiator. But if it doesn't open fully to give you normal coolant flow you will over heat.
So that test is good to detect a completely stuck "closed" t-stat.
Even if the hoses get hot, if you suspect a bad t-stat, it needs to come out and go into a pot of boiling water to fully test it.
Old Mar 9, 2011 | 09:11 PM
shane0328's Avatar
well ill proly just leave it be for now its not really effecting anything but thanks alot for all ur input i know a little more about whats going on now
Old Mar 10, 2011 | 02:39 PM
samson_420's Avatar
If you want to know some true temperatures, get a infrared temp. gun and go at it.
My 98 reads normal now, but for a while it would read 180 or so on a hot *** day. . . . The gauges are just not that accurate in these cars.
