Sponsored by: CARiD
Replacing oil pressure sensor.. Advice
Old Mar 12, 2011 | 07:56 AM
T.Williams's Avatar
Default Replacing oil pressure sensor.. Advice
Im replacing the oil pressure sensor located on the back of the intake, anybody have any advice on replacing it.
Old Mar 12, 2011 | 11:50 AM
sjsingle1's Avatar
get the special socket.........got mine from vato zone..........you can do it with the intake in place.......but i have never done it that way....its pretty crowded back there......i suggest you pull the intake......and while its off.........install a LS6 valley cover
Old Mar 15, 2011 | 08:11 PM
jrpimp00's Avatar
Like stated above, get the socket. I think mine was $11 bucks at the zone. I did mine with intake in place, no problem.
Old Mar 15, 2011 | 08:23 PM
RARON455's Avatar
Use the socket,,I have never done it with the intake on though,,
Old Mar 15, 2011 | 08:33 PM
jim ravencraft's Avatar
Hi.
The above post is correct! R&r unit
using caution to avoid cross threading new unit. Tighten properly and check for leaks and proper operation.have a blessed week............jim
