Sponsored by: CARiD
Alternator Question
Old Mar 12, 2011 | 04:09 PM
Ws6DieseL's Avatar
Default Alternator Question
I'm in the process of installing solid motor mounts and I thought while I have the alternator pulled out Ill replace the alt., plug, plus the positive wire assembly. Well when I pulled the alternator out there was no plug in it and no where to be found. I'm wondering if it is ok to run without that plug and if not where does the wire lead to so I can try to find and hook it up. Thanks
Old Mar 12, 2011 | 05:48 PM
LS6427's Avatar
If you're talking about the excitor wire that plugs into the top of the alternator.....you better find it otherwise your PCM will never be able to tell the alternator to start charging the battery after engine start. It comes out of the wiring harness right above the alternator.
Old Mar 12, 2011 | 09:20 PM
Ws6DieseL's Avatar
theres a wire I found thats right above it but it has no plug on it just has a metal prong on the end and the wire is very skinny compared to the new excitor wire I just bought
Old Mar 12, 2011 | 10:06 PM
sjsingle1's Avatar
the new alt plug i got from ebay .........the wire was waaay thicker than the stocker......not a problem
Old Mar 12, 2011 | 10:45 PM
LS6427's Avatar
Splice it onto that little wire with but-connectors and shrink wrap and you're good to go. GM made that wire pretty damn skinny for some stupid reason.
And like mentioned....that ebay wire for $10.00 with new plug and all is a great part.
