steering wheel removal
Thanks
Edit: Bought a different steering wheel puller and it had the correct bolts.
Next question -- How do I remove the "shaft lock" ... #6 in this diagram
http://shbox.com/1/steering_column_exploded.jpg
Does it just pull off? I don't want to break anything..
https://ls1tech.com/forums/general-m...mn-repair.html
I'm working on a '96 and the lock plate was different, though it was removed the same way. The hazard light switch was also different, and was a bit more challenging to remove than simply taking a bolt out. For anyone doing this, removing this piece should be pretty straight forward.
