Sponsored by: CARiD
Elusive Voltage Draw
Old Mar 16, 2011 | 03:40 AM
kyoytey1693's Avatar
Default Elusive Voltage Draw
After my car sits for a week or so it wont start. It will crank a little but go. The battery drops down to 11 volts and some change. Typically I leave my battery tender on it and its no big deal. But I don't have any new parts to install right now so I figured I would try to fix something.
I put a volt meter between the battery and the positive cable and for a moment it shows about a 12v draw and then immediately drops the less than .02v.
I hear some solenoids clicking when I reconnect the battery. I'm not sure exactly which ones but I know if I remove the underhood fuses for the L/R headlights, the solenoids no longer click when reconnecting the battery.
The battery is an Optima red top. It's about 3 years old. I have left the battery disconnected for a few days and it shows no signs of losing voltage on its own. I load tested it and even reconnected the cables and the car started. So, I am almost positive the battery is good.
Right now I am leaving the headlight fuses out for a few days and monitoring the battery to see if it continues to lose voltage.
What else can I check? What other testing can I do? Has anyone experienced anything like this? If I am no longer losing voltage with the headlight fuses out, I will assume the problem is in the headlight circuit. But if that is true, what the hell could it be? All of those components work without flaw as far as I can tell.
Old Mar 19, 2011 | 05:44 AM
Steve Gunn's Avatar
Having your alternator tested is the first and easiest thing to do. I overlooked this for awhile because I saw the guage was in the normal range.
I too just trickle charged the car often, but a long trip with the headlights on forced me to finally fix it. Any knucklehead at any auto parts will have a decent load tester and be glad to do it. I went with a junkyard 145 amp truck alternator and I can let my car sit for weeks now with no trouble.
If that's not it, start pulling fuses and check for a drain across with an ampmeter. Look first to your aftermarket stuff. Check for corrosion, loose head or block grounds, etc.
Good luck!
Old Mar 21, 2011 | 03:56 AM
Thats a good thought on the alternator. You never think the think that keeps you charged could be the culprit. I'll take it and have it tested. Thanks man!
Old Mar 21, 2011 | 07:10 AM
Steve Gunn's Avatar
You're welcome! I hope it's something easy. They tested mine on the car, btw.
