Sponsored by: CARiD
No heat AGAIN.....HELP!!!
Old Mar 21, 2011 | 07:35 PM
ytownls1's Avatar
Default No heat AGAIN.....HELP!!!
Ok when i bought my 99 z28 with 53k miles it had no heat, sent it back they flushed it. Heat worked for 2 days then went again, sent back and they pressure flushed it.....Heat worked for 2 days again!!!
3rd time sent it back they put in NEW heater core and radiator.....Heat worked for 3 weeks......AGAIN NO HEAT
Sent it back for the 4th time, what can it be...I have brand new thermostat,radiator and heater core, and all hoses are new...So other then that they said they are contacting GM.
PLEASE HELP!!!
Old Mar 22, 2011 | 09:05 PM
joshp14's Avatar
When engine is hot, what do the heater hoses feel like? Perhaps something on your system is clogging up the heater core? What does the coolant look like? I would assume at 53k it's probably ok especially after they have replaced all those parts.
Old Mar 26, 2011 | 10:43 AM
ytownls1's Avatar
ahhh they found the problem, they took out the freeze plugs, and cleaned the block, and said chunks were coming out....That the guy must of used LOTZ of stop leak. Heat work to GOOD now lol.
