Sponsored by: CARiD
Multiple Misfires
Old Apr 9, 2011 | 06:15 PM
|2ocky's Avatar
Default Multiple Misfires
So I have an 01 z28 with long tubes and tsp true dual system that I recently added a tsp 233/239 cam to. The car has a solid basemap tune on it. I have been having multiple misfires that when scanned showed up on each side of the motor. Now that I have the basemap it is harder to pinpoint exactly which cylinders because of the tune not registering misfires. So far I have replaced the plugs and the o2 sensors but still having the same results, the wires look to be in good shape. If someone could shine some light on something I may be overlooking that would be very much appreciated. We did remove the motor when installing the cam and everything seemed to go rather smooth but I am leaning towards something that could have gone wrong there. Any input on what could be causing this?
Old Apr 9, 2011 | 06:54 PM
|2ocky's Avatar
Also it has misfired at idle but it is mostly under partial throttle and below 3000 rpms.
Old Apr 10, 2011 | 04:19 PM
|2ocky's Avatar
anybody?
Old Apr 10, 2011 | 04:35 PM
KevinR's Avatar
Was it tuned at all after you did the cam swap? If not, then that's probably what your problem is
Old Apr 10, 2011 | 05:59 PM
|2ocky's Avatar
Frost had it on the dyno to tune it but he said it wasn't right mechanically, so he put a basemap tune on it and I am going to bring it back once I get this issue figured out.
Old Apr 10, 2011 | 08:54 PM
14k's Avatar
14k
not right mechanically?? did he say what he meant exactly by that?
Old Apr 10, 2011 | 09:09 PM
|2ocky's Avatar
He was speaking about the misfiring. It is a mechanical problem and not a tuning problem. It is hopefully a small problem but I haven't figured it out yet.
