Sponsored by: CARiD
Still not Starting!!!
Old Apr 29, 2011 | 07:55 PM
GOT LS1's Avatar
Default Still not Starting!!!
so when i turn the ignition over every thing lights up, i engage the clutch turn the key over and nothing... took the starter out and had it tested and that was good too. checked the power at the starter and im getting 12v... im all out of options. any info would be greatly appreciated
Old Apr 30, 2011 | 11:30 AM
f-body.cbct's Avatar
Are you getting a 'security light' on your cluster?
Old Apr 30, 2011 | 04:10 PM
rwb's Avatar
rwb
Check the starter relay. It could be that easy, or not.
Old Apr 30, 2011 | 06:57 PM
bad_408_vert's Avatar
Did you try the AC and Starter Relay swap like I said in your other thread?
