Sponsored by: CARiD
driveshaft humming?
Old May 10, 2011 | 04:41 PM
O2Form's Avatar
Maybe they got wom wom wom go away is a can you could put in there too?
REREAD MY POST ABOVE! and find a shop to check it....otherwise start looking for a new rear cause shortly bad things are gonna happen to yours!
Old May 10, 2011 | 05:42 PM
bp m1009's Avatar
Originally Posted by nik1703
gets louder with speed between 30-60, but then it completely disappears around 80. now i have kind of a "wom wom wom" noise on decell in 2nd gear when coming to a stop. (whether or not 2nd is engaged)
hmmm... does the noise get any louder if you roll onto the gas? Does the sound become more obvious under a load? if not its starting to sound possibly like wheel bearing now. is it kind of a droning sound? like big mud tires goin down the road
Old May 10, 2011 | 06:12 PM
projectX's Avatar
Rearend
Old May 11, 2011 | 08:46 PM
nik1703's Avatar
Its changes depending if the throttle is on or off, and not how much i push the throttle. It is a droning sound at certain speeds, and a wom wom sound on decell.
wheel bearing is a possibility. i don't know, someone who has a more experienced ear would have to hear it. also, when I put that additive stuff in to the diff, i didn't make a damn difference.
Old May 14, 2011 | 02:09 PM
critt50's Avatar
Read your sig, nowhere does it say 9" rear. Being that you have the mods you do, I'm sure you drive it accordingly. Your rear end is shot. Time for an upgrade...
Old May 16, 2011 | 11:37 AM
bp m1009's Avatar
ok heres what you do. get under the car and see if you can move the pinion flange at all, try and move it up down or side to side...it should have no play, any play means the pinion has loosened up and its time for new pinion bearings!
Old May 16, 2011 | 01:16 PM
rabbit320's Avatar
sounds like axle bearings! (had mine rebuilt and theyre doing the same thing 2 years later) get a friend to sit back there while driving and listen for one side or centrally located sound...
