HELP Car voltage issue, now no start
i went through about 4 alternators , before i finally just replaced all my positive and negative cables .
you can order a set from GM for a bout 70 ... not too bad.
if not that , look to see if your power steering pump is leaking onto your alternator , people have told me that this will sometimes cause the alternator to go crazy.
**if its when turning, your PS pump is probably dead and leaked all over the ALT, OR most likely the crappy stock PS cooler. I removed it and since then its all better!!!**
..so many thing to look at..
