Water Pump Gaskets
The original water pump had paper and when I replaced it it came with paper.
I would use the alum but its a bit thicker and not sure if it will throw off the pulleys alignment or anything.
What ya'll think?
Thanks
Yea wasn't to concerned with the water pump pulley but the tensioner pulley since it is ribbed and thought that the rear edge of belt will rub against the back side of the pulley.
I did install it with the metal gaskets but engine still out of truck so can't tell what its going to do.
