Battery issue.
If so, you should probably check to make sure the solenoid is getting voltage.
I assume you are hooking the jumper cables up with the negative grounded to the body of the car you are trying to start? If so, maybe your negative battery cable isn't connected properly to the car?
If you hook jumper cables up to the new good battery and the gauges come on - that would indicate a problem between the battery ground and the car. Or... hook the jumper cables up to the bad battery directly and then grounded to the body of the car you are jumping from. If the gauges don't work under this system, that would also confirm the same thing.
