LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   General Maintenance & Repairs (https://ls1tech.com/forums/general-maintenance-repairs-102/)
-   -   driver's window rattle (https://ls1tech.com/forums/general-maintenance-repairs/1427447-drivers-window-rattle.html)
rggbly May 26, 2011 02:12 PM
I've replaced the window motor on my drivers side so it goes up and down fine. my problem is that the window rattles a lot if it is not all the way up. it's scratched my tint off all the way down the window. anyways i took the door panel off and noticed something odd. i took some pics of it. i need to get this thing supported how it needs to be so i can retint my windows and not mess them up. also both alighnment mechanisms are there with felt pads and against the window properly so that is not the problem
pics of what i'm concerned about:
http://imageshack.us/g/30/image0001s.jpg/
wssix99 May 27, 2011 08:33 AM
Unless the window is all the way up or all the way down, it will move a lot. This is a "feature" of the design.
That plastic hook is absolutely needed. It engages the upper stop behind the door panel. The upper stop secures the window all the way up and keeps it from ripping your weatherstripping off, breaking the glass, etc. It doesn't have anything to do with the rattle.
Where is your tint being scratched?
You may also make sure the anti-rattle sleeves are in the correct place on your door handle rods and make sure you don't have a loose motor or regulator.
67RSCamaroVette May 27, 2011 09:43 PM
Check the fuzzies that hold the window against the outer door weatherstripping. If one of them (2ea) is broken, as they commonly are; you need to replace it. I have a pair laying around I was selling, I can take a pic if need be. The "rattle" is metal on glass.
rggbly Jun 1, 2011 02:51 PM
this kind of rattle isn't normal. my passenger window doesn't do this at all. the tint is scratched about 8 inches or so from the back of the window. the felt is in place on both pieces that stabilize the window.. thanks for the info on that hook. i wasn't sure what it's purpose was.
how can i check the regulator. i had a guy with the same problem tell me he had a bad regulator
djfury05 Jun 1, 2011 03:11 PM
have you actually taken the door panel off to inspect the window brush assemblies or did you just pull the top of it back to see if it was there? If not, you need to pull the door panel off and run the window up and down to see if it is actually staying in place. Ask me how I know.
rggbly Jun 2, 2011 01:40 PM
door panel has been off and i can't see what's loose
rggbly Jun 2, 2011 01:41 PM
the brushes are not the problem at all. it's got to be something inside the door. I just don't know what im looking for and nothing is jumpin out at me
wssix99 Jun 3, 2011 10:11 AM
Take the speaker out and use an inspection mirror to look in there. You also have a good look from the back under the clear plastic.
rggbly Jun 6, 2011 03:17 PM
i took the plastic all the way off the door today and got a good look inside the door to see what the problem is. the worst of the movement seems to be in the front of the window. I mean it's as loose as could be i can move it side to side at least an inch both ways in the front when the window is all the way down. (thats at the bottom) i can also pick up on it about an inch. it is on the the tracks and everything seems to be connected correctly...but somethin has GOT to be worn out.
wssix99 Jun 7, 2011 12:51 AM
Impossible if something isn't attached or off a track. Did you check the roller that attaches to the rearward vertical track? They break often and are what constrain the window from moving side-to-side.
rggbly Jun 10, 2011 03:04 PM
I will see if i can light it up inside the door and take some pics. maybe you or another member can see somthing i'm missing. I've had two sets of eyes on it and we couldn't figure it out
JD_AMG Jun 10, 2011 05:15 PM
Sounds like something broke off the track. Check out this thread: http://www.camaroz28.com/forums/showthread.php?t=541458
wssix99 Jun 10, 2011 05:18 PM
If you can tug on the glass and have it move, 100% something is broken.
The glass mechanism is constrained at 5 points. Two rollers in the channel attached to the glass, one roller in the channel attached to the lower inside of the door skin, one roller attached to the vertical track at the back of the door, and the four rivets attaching the regulator to the door.
If your glass moves under manual "manipulation" then one of those five items is screwed up. If you have side to side movement, its probably the rear vertical roller/track or the regulator attachment. (Both of those can be seen from the outside.)
rggbly Jun 15, 2011 08:55 PM
can you specify where i need to look a little more? I see where your gettin at now though. From that description it sounds like that would be the part to be out
wssix99 Jun 16, 2011 12:28 AM
This is probably the problem you have: https://ls1tech.com/forums/general-m...w-related.html
needtransam Jun 16, 2011 06:42 PM
I have almost the same issue, wheneve I go over a bump my windows rattle or if I go over anything it rattles alot, It only rattle when its NOT all the way up or all the way down???
wssix99 Jun 16, 2011 09:27 PM
If you can't move the glass around by hand, its definitely not the same issue.
:hijack:
rggbly Jun 21, 2011 07:06 PM
checked for that and mine is totally intact there. I'm going to pull my passenger door panel off and see what if i can figure out what's missing. there is just absolutely no support on the front of this window...im starting to wonder if something is just completely missing because i can't find anything loose or broken
wssix99 Jun 21, 2011 10:16 PM
That was probability #1. #2 is this problem: https://ls1tech.com/forums/general-m...-included.html
arrowheadfan287 Jun 16, 2012 06:44 PM
drivers window messed up
i found out what was wrong with my window the braket at the back of my window broke now my window is sliding all over the place wont go up right. its causing alot of difficulties and am wondering if the only way to fix it is to replace the window or is there anyother ways
© 2026 MH Sub I, LLC dba Internet Brands
