Sponsored by: CARiD
Blowing Dip Stick
Old Jun 8, 2011 | 07:02 PM
pantera408's Avatar
Default Blowing Dip Stick
I'm blowing my oil dip stick out at high RPM's (6K+) and oil everywhere in engine compartment.. Please help... It's very annoying.
Has Built motor heads ,Cam , 11.25.1 Comp. , Ect..Aslo 6speed car...
Thanks
Sean
Old Jun 8, 2011 | 08:13 PM
jstevens400's Avatar
you will get that with high power/high rpm motors. Might check your EGR valve and see if its working properly? Maybe that could have something to do with it you could also pick up a locking dipstick & tube from jegs or summit i know a lot of people at my local track use them on their lsx motors. Be careful u don't want it to blow out and u get a piece of dirt or something down in there that wouldn't be a good day. lol
Old Jun 8, 2011 | 08:41 PM
pantera408's Avatar
I have HV oil pump as well...Why does this happend?? does have air pump delete as well.. how do I delete egr if not already done...
Thanks
Old Jun 8, 2011 | 10:35 PM
garygnu's Avatar
do a compression check,you probably have some ring blow by.you probably have high crank case pressure. a crank case Vacuum pump can band aid the problem.or rebuild the engine.
Old Jun 9, 2011 | 11:29 AM
crazyc1123's Avatar
Ditto that. To much crank case pressure is usually the cause. Def do a compression test cause you may have some bad piston rings.
Old Jun 9, 2011 | 12:31 PM
BIG_MIKE2005's Avatar
Agreed, only reason I can think of for blowing the dipstick is too much crank case pressure. Is your PCV deleted with it all capped off & no breathers? You gotta watch that crank case pressure cause if you just toss on a "locking dipstick" like suggested and there is nowhere else for the pressure to go its gonna start pushing seals out to escape.
Case & point, my dipstick tube isnt even bolted in, its hanging loose. Has been for over 3yrs & I daily drive mine. I have above stock compression & my tube never moves. I have the AIR/EGR delete done but my PCV is still in place. Never had a single issue.
