Sponsored by: CARiD
Leaking from everywhere
Old Jun 14, 2011 | 07:48 PM
01SuperSport's Avatar
Default Leaking from everywhere
Well the car had a major engine and tranny leak before the tranny went out. I replaced it with a built tranny and had my mechanic change the gasket in between the tranny and motor which fixed my motor oil and tranny problem. Went to go change my oil today and the guy told me I had leaks from the powersteering, rack and pinion, and from the motor again. I went under the car and it does look like it's leaking from somewhere but just don't know from where. I highly doubt it's coming from the same leak I fixed before. The oil filter had oil on it when I looked under the car and I'm thinking this guy is right being that the bottom of my car has little but fresh oil. I'm trying to find out what this would run me if it were to be leaking from the rack and pinion as well as the powersteering???
Old Jun 15, 2011 | 06:28 AM
sjsingle1's Avatar
my car leaks more than a Iraqi oil pipeline
Old Jun 15, 2011 | 09:25 PM
INMY01TA's Avatar
Wipe everything down and get under it and look with the engine running.
Old Jun 15, 2011 | 10:40 PM
Old Jun 15, 2011 | 10:45 PM
Thanks for the tip. I'm going to change the oil this weekend since the douche said he couldn't change it because the car was leaking I'll wipe down the car and try to check out if I can spot anything. It's just that the leak is small and doesn't really leave noticeable stains in the driveway. Maybe a hose somewhere
Old Jun 19, 2011 | 02:03 PM
So I got under the car yesterday to change my oil and didn't see any hoses leaking. Seems like the leaking is coming from the oil pan and dripping all over the front suspension. Probably has to have the gasket changed or something? Looks like a pain to replace and pricey. Anyone have an idea of how much this will run me?
Old Jun 19, 2011 | 05:04 PM
sjsingle1's Avatar
i have narrowed down my leak to.....rear cover......rear seal.......oil pan.........front cover......easy fix
Old Jun 19, 2011 | 05:42 PM
SparkyJJO's Avatar
If your pan gasket is leaking, check the pan bolts first and make sure they are at proper torque. If they have loosened up a tad that can make it leak. Can't hurt to check, and if it doesn't fix it, well, you're not out anything.
Old Jun 20, 2011 | 10:38 PM
Not a bad idea thanks for the tip.
Old Jun 20, 2011 | 10:47 PM
Before I changed my oil, I had the little oil change light on in the gauges. For some reason it still pops up at every start. Did I miss something???
