Running Hot @ Speed Need help inside....
BUT I decided to do some checking with my temp gun and noticed something strange. car running upper hose read 179 degrees.. lower hose was 174.... the outer edge before the plastic (cap side) was 194, other side was 200... The plastic edges were both 202 degrees, But the middle of the radiator was 172 degrees. Shouldn't it be the same temp or close as the outside edge?
I'm thinking I might have a blockage in the radiator...
The fan motors are original. I compared them to my friends 95 Z and his fans pull much more air.
Didn't mean to highjack. Just wanted to let you know I am having a similar situation.
Replaced the old radiator appeared to be original and figured why not. It had a bunch of crap in it.
Removed the Coolant tank and cleaned it out with gas and engine degreaser like someone recommended and the amount of crap and crud that came out of it was ridiculous.. Put it all back together and still the same problem.
Today: Removed the RA kit from in front of the radiator and temps never went over 190 degrees. I guess I have one of those few cars to where I can't run the kit without overheating. I think the main reason LS1 cars can get away with it is the big opening in the middle of the grill, My LT1 bumper doesnt have that so all the airflow needs to come from the air deflector. I hope that the new bumper 6LE is making will help the cause so I can run it again but for now I had to remove it.
But....you figured it out. Thats cool. Pun intended
yes the air deflector is on the car and has never been off.
