Sponsored by: CARiD
Replace Light in ASR Traction Control Switch?
Old Jun 24, 2011 | 08:41 PM
libertyforall1776's Avatar
Question Replace Light in ASR Traction Control Switch?
Is it possible to replace the light in the ASR Traction Control switch ('02 Camaro)? Anyone done it? What bulb type/# is it?
Old Jun 11, 2012 | 03:20 PM
Jhall83's Avatar
*bump*
My ASR switch backlight is out as well
Old Jun 11, 2012 | 03:47 PM
Black96z28's Avatar
Originally Posted by Jhall83
*bump*
I believe it is possible. My illumination on my fog switch is out and the indicator on my asr is out... Wasn't going to mess with it but now I want to. Give me 30 minutes.
Old Jun 11, 2012 | 04:33 PM
Black96z28's Avatar
Yes, you can in fact. It takes some patience. I took some pictures if you need any visual help.
If you are going to replace them, you will need to know how to solder. The bulbs are 7219 or equivalent. Each switch has 2 bulbs.
https://ls1tech.com/forums/stereo-el...ht-switch.html
Last edited by Black96z28; Jun 11, 2012 at 07:07 PM. Reason: bulb number correction
