Sponsored by: CARiD
Removing Headlight Motor Question?
Old Jul 7, 2011 | 06:24 PM
El-Ess-Won's Avatar
Default Removing Headlight Motor Question?
I'm trying to separate the headlight bracket/headlights from the headlight motor itself, but I don't know how to remove the swinging arm the comes off of the motor/bracket. I took the nut off of the arm where it connects to the motor but I guess that isnt it?
Old Jul 7, 2011 | 06:39 PM
Element's Avatar
The arm should bolt to the electric motor on the shaft (upper left of the box you made). It might take a little prying, but it should pop off.
Old Jul 7, 2011 | 06:46 PM
bigj2717's Avatar
Yeah it'll come off. You might want to add some penetrating lube and let it soak then pry on it with a screw driver.
Old Jul 7, 2011 | 07:11 PM
El-Ess-Won's Avatar
okay thanks, that's what I was wondering, just didnt want to pry and break it
Old Jul 7, 2011 | 07:14 PM
bigj2717's Avatar
Don't go crazy but the first time it takes some effort. After that it should come off by hand
