Sponsored by: CARiD
Overvoltage on start-up???
Old Jul 9, 2011 | 03:00 PM
1badzls1's Avatar
Default Overvoltage on start-up???
whats up fellas, heres what i got, on start-up, say, in am. the voltage shoots to like 16-18 volts. and stays there for about 5 minutes while driving, then will slowly creep down to about 13-14. its a little bit of a problem because i keep blowing turn signal bulbs. what is going on? bad ground????
Old Jul 10, 2011 | 12:44 AM
sjsingle1's Avatar
check the wire coming out of the alt
Old Jul 11, 2011 | 05:51 PM
wssix99's Avatar
Save the manuals!
You should test the alternator. The voltage regulator in it may be failing. (This is not good for your electronics!)
Old Jul 11, 2011 | 10:10 PM
1badzls1's Avatar
ok i will check the wiring tomorow. then mabe see about testing alt. thanks guys
