Trembling in 4th gear ?
i could feel a chattering or a shaking. felt like the rear end was going to fall out.
upon further review by a friend, the pinion bearing was shot and there was play up and down. his initial thought was that the ring and pinion were grinding together with the play. end result was i bought an entire rear end rebuild kit, axles and 3.73 gears. after that was done, the yolk/pinion seal was leaking. after a new yolk was installed i took the car out. now with the 3.73s and the car at 40mph the rpms are at 1500 or so. under light acceleration the car still has the trembling.
i changed the fuel filter ( hadnt been changed in about 25K miles / 7 years )
took the car for a ride, still there.
trembling might not be the right way to describe it. its almost like when a manual transmission vehicle is at low rpms and in a higher gear and its starving for gas and it feels like its going to die out.
could it be the trans ? maybe the yank TC ?
if it was a misfire wouldnt a SES light come on ?
plugs and wires were done with the headers 6 years ago. plugs were changed with the cam swap 2 years ago ( kept same msd 8.5 wires )
i havent put many miles on the car in the last 2-3 years. maybe 10K total.
need help guys,
thanks in advance
The catch is looking to see if the problem goes away at higher speeds. That's the signature of a balance issue. My wife just got 4 new tires on her truck and the techs screwed up three of them! (The thing drove like a tank over 45 mph.)
cable ends look in good shape.
remove the plug.........looks ok to me, normal wear. no excessive stink, no fluid electrode and head are straight and in good shape.
sooooooooooo, i reinstall it and was looking over the AIR system, because i want to remove it and the EGR valve.................and what is staring me right in the ******* face ????????????????????????????
plug #8 wire...that's right, it is not plugged to the ******* ignition coil. is this my problem ? car running on ******* 7 cylinders ? how bad is this ? have i done any damage ? who knows how long this has been "off "
