another CEL code? what is this one about?
Two suggestions:
- You should take your car to get the A/C checked ASAP. Your compressor may be going out and not holding the correct pressures. (This would cause your A/C temperatures to be out of range.) If that's the case, you'll want to replace it before it blows and causes you a more expensive repair.
- Go to Helm and get the Factory Service Manual for your car. (You may also find cheaper used ones on eBay.) There will be full descriptions for each of your codes and instructions on how to diagnose the problems.
