Egr problems P0401 and P0405
Also while the EGR is off, start the engine and make sure that you have a lot of exhaust shooting out the pipe that connects to the exhaust manifold and a lot of vaccum sucking through the pipe that connects to the intake. If either one of those tubes happens to be clogged it will also cause issues.
My money is on EGR valve itself or wiring, because of the P0405. That is a circuit malfunction code.
These may also be helpful to you,
http://www.obd-codes.com/p0401
http://www.obd-codes.com/p0405
