Sponsored by: CARiD
car will only start on second try
Old Jul 26, 2011 | 08:28 PM
waltsfastz's Avatar
Default car will only start on second try
2000 camaro, Z28. When It is cold the car will crank good but not hit a lick. Stop cranking and hit the key again and it will fire right up. After it has warmed up it will start. Any suggestions?
Old Jul 26, 2011 | 08:36 PM
LS6427's Avatar
MAF cleaner.
Old Jul 26, 2011 | 09:04 PM
NBM99SS's Avatar
Check fuel pressure. Sounds like it may be bleeding off after sitting
Old Jul 26, 2011 | 11:07 PM
ws6outlaw's Avatar
^ x2 sounds like fuel pump might not be priming right off the bat or something along the lines of fuel not getting there immediately
Old Jul 27, 2011 | 09:30 PM
waltsfastz's Avatar
Ill check tommorow, Clean MAF and cheeck fuel pressure. car has 180,XXX miles on it so Its likely it could be any and all of the above.Thanks
Old Jul 27, 2011 | 09:43 PM
LS6427's Avatar
MAF is just cheap and takes 5 minutes. Do that first. But I guess borrow a fuel pressure tester from the parts store if they offer that, while your there.
Old Jul 27, 2011 | 10:15 PM
k0261886's Avatar
Next time you start it cold turn the key to the on position but don't start it. Listen for the fuel pump to prime and then turn off, then start it and see if you have the same problem
Old Jul 29, 2011 | 12:37 PM
mike171562's Avatar
sounds like what my car was doing before I replaced the fuel pump.
Old Jul 30, 2011 | 03:10 AM
The Mighty Texan's Avatar
Same problem here, pretty sure its FP.
Old Jul 30, 2011 | 06:44 PM
jaxcam02's Avatar
Fuel Pump get the Walbro
Old Jul 31, 2011 | 10:40 AM
FiredUpZ28's Avatar
Usually thats gonna be info you want in your first post. Your gonna have to start small like all these guys are saying. Because at that mileage it could be anything.
