Sponsored by: CARiD
98 ls1 bogs...help plz...
Old Aug 2, 2011 | 12:02 AM
LS1TA_956's Avatar
Smile 98 ls1 bogs...help plz...
my car is a 98 transam a4 here is the problem I try to peel off my car bogs somtimes it also feels underpowerd I floor it all the way down and wont do anything but bog the check engine turned on and took it to check the cels it said it was running either rich or lean and both oxygen senors where bad.
Please help am new to ls1's and ls1tech thanks in advance for any input
Old Aug 2, 2011 | 12:21 AM
LS6427's Avatar
I would look into things a little bit further because to lose two 02 sensors, on different sides anyway, at the same time is a hell of a coincidence. Same side I can see. But two have failed before at the same time, just saying check into a little bit.
Get a live scan to see if they are NOT switching properly. If they're not, get two new sensors. They're cheap....$33.00 each for the best ones....Densos.
You can change them yourself in minutes, just have to get the front end off the ground, or jack up each side separately. All you need is a crescent wrench.
Oh....and STOP flooring it with the engine running like that....you could completely destroy the internals with misfiring and sputtering going on and you go wide open throttle.
Drive it very casually and nicely till you get it fixed.
Old Aug 2, 2011 | 12:41 AM
LS1TA_956's Avatar
Thanks alot ls6427 I just got it but has some problems also theirs some fumes comimg out of the oil filler when its on or when I turn it off it looks like vapor
Old Aug 2, 2011 | 12:45 AM
LS6427's Avatar
Fumes???? You mean little puffs of smoke? Might have a bad ring(s), you shouldn't be getting anything blowing out of the oil filler neck.
Old Aug 2, 2011 | 01:00 AM
LS1TA_956's Avatar
Wher can I get them that cheap here in autozone they sell for 69.99 each the densos
Old Aug 2, 2011 | 07:29 AM
wssix99's Avatar
Save the manuals!
Before you spend real money, I'd recommend cleaning your MAF. (just get a special $5 can of MAF cleaner) A dirty MAF can cause you to run lean so bad that you throw O2 codes. (Even though the O2 sensors are fine.)
Are you running an oiled air filter?
Old Aug 2, 2011 | 01:30 PM
LS6427's Avatar
amazon.com and rockauto.com......approx. $33.00 each, sometimes they vary up and down a few dollars. One day shipping with Amazon. Part # 2344025 Denso....16 inch long wires.
BUT....like me and "wssix99" have said earlier....look into other things first. Definitely try cleaning the MAF...just spray it, DO NOT touch the sensors inside the MAF with anything, just spray it like crazy. You cannot over spray it. I use like a 1/4 can all over it. Spray it through the screen all over it and also clean the whole screen. Also, while its off spray the hell out of the IAT sensor thats in the lid. Then spray the hell outta the TB blade whole its full open as to clean the side walls all the way around the TB opening. I just spray it all then use my fingers to wipe it all clean, then spray it again to rinse it.
And yes.....if you have a K&N filter....lose it. Get a Mann paper filter from rockauto.com....they are friggin awesome, built very strong, and cheap. I just got mine the other day to try. Great paper filter.
