Sponsored by: CARiD
power steering whine......
Old Aug 18, 2011 | 08:31 PM
Floorman279's Avatar
Default power steering whine......
so when sitting still, if i turn it left or right while sitting still, ill get a whine........shoot me but i havent even checked the fluid....woops......while moving just a little it wont do it......its a 98 z28 with 95000 miles so i guess i gotta assume that its original fluid........so whatsthe best way of getting all the old fluid out?
Old Aug 19, 2011 | 12:17 AM
blackbird0230's Avatar
Turn it like you said to make it whine and get it a rev, if the whine gets louder with the Rpms than you can be sure it is the ps pump, I'd check your fluid, mine was whining too and I was low, hasn't done it since
Old Aug 19, 2011 | 12:52 AM
lemons12's Avatar
........I would just check the fluid. After that probably add some.
Old Aug 19, 2011 | 12:18 PM
its not worth taking theold out and adding new?
Old Aug 22, 2011 | 08:59 AM
HoLLo's Avatar
Don't take this too hard, but common sense seemed to have received a brutal kick off these forums..
Of course its worth adding new fluid, at the minimum CHECK THE FLUID LEVEL and top off if needed. Get a turkey baster thing and suck the fluid out and add some more, turn the wheel a bunch to cycle it through, and repeat. I'm assuming I should add in this - dont turn the wheel until you've topped off the fluid
