Sponsored by: CARiD
Heater/fan problem
Old Oct 17, 2011 | 01:39 AM
jeff5755's Avatar
Default Heater/fan problem
97 Formula. Has no a/c unit at all. The heater will blow nice and hot, but the fan will not turn on high. It works on the other speeds. Any thoughts on what I need to replace? The search garnered no results, but I could have missed it.
Old Oct 17, 2011 | 11:51 PM
jeff5755's Avatar
No one has ever dealt with this?
Old Oct 18, 2011 | 01:42 AM
wrencher's Avatar
wrencher
Check the high blower relay, the fuseable link that powers it, & the switch.
Those would be the 1st on the list.
Old Oct 18, 2011 | 09:06 PM
joecar's Avatar
There is a resistor module which consists of a resistor coil with taps for each of the fan speeds...
remove it and look to see if the high-speed end of the resistor coil has come loose or is burnt out.
Old Oct 18, 2011 | 10:12 PM
wrencher's Avatar
wrencher
The resistor is by-passed for full speed operation.
He has the rarer type of failure. Usually it's the lower speeds that dont work lol.
Old Oct 19, 2011 | 08:55 AM
joecar's Avatar
Yes, you are correct... the resistor module is bypassed and a relay switches the blower motor on.
Old Oct 24, 2011 | 01:55 PM
Jr.Samples's Avatar
So you can look and see the voltage ar the fan motor. High should be 12V. It is amazing this technology has not changed over the years.
I had the exact same problem on my 79T/A with the resistor pack. I finally bypassed it and put it to a switch on the dash. On high or off. I didn't care at least it worked.
