Sponsored by: CARiD
What does an air pump relay do?
Old Nov 12, 2011 | 07:34 AM
ShovelMan's Avatar
Default What does an air pump relay do?
Or what does an air pump do? I was checking my car yesterday to see if any fuses have gone bad and I saw that i'm missing a relay for "AIR PUMP"
What does it do?
Old Nov 12, 2011 | 08:41 AM
dutinsss's Avatar
it's your secondary air injection system. if you have stock exhaust manifolds you'll notice a pipe going to the top of each one. they inject air into your exhaust to warm the cats up quicker so they are more effective. a lot of people delete it so if your relay was missing that's probably what the previous owner did.
Old Nov 12, 2011 | 10:13 AM
ShovelMan's Avatar
what is the purpose of deleting said relay?
Old Nov 12, 2011 | 11:29 AM
RARON455's Avatar
The air pump is to inject clean air into the ehxaust to try and reduce the amount of emissions from the engine by diluting them with uncontaminated air. In a nutshell.
Old Nov 12, 2011 | 07:05 PM
ShovelMan's Avatar
But why would people not want clean air into exhaust? Does missing relay cause a code to be returned?
Also whenever I let go of the gas, my car makes a supreme farting noise. My car is all stock, just wondering what it could be.
Old Nov 12, 2011 | 10:12 PM
Jr.Samples's Avatar
Lay off the Mexcan foods.
So I understand this air injector is electrical not pully driven like older ones? So why not keep it?
Old Nov 13, 2011 | 05:14 AM
O2Form's Avatar
YOu should have a code set if the relay is not there. The relay operates the air injection motor, the pcm uses it to operate the air system and to perform a bunch of tests on the 02 sensors and check if the cats are working properly etc. If the car is bone stock it should be working. Sounds like you car was modded, maybe the cats were gutted etc?
Old Nov 13, 2011 | 08:22 AM
ShovelMan's Avatar
how do I check if my Catalytic converter was modded? What would be the typical mod done to it?
Old Nov 15, 2011 | 03:02 PM
Zlow28's Avatar
sometimes it wont, most of the time it will. When its obd1, it shouldnt throw a code if you have a good fuse for the air pump.
The sound can be a missing catalytic converter. They sound raspy on some setups
The pump itself will rob you of a couple horses
check under the car, and look for any weld signs around the cat.
