Sponsored by: CARiD
Weird Noise from Engine Bay HELP
Old Nov 21, 2011 | 01:43 AM
camaro1999ss818's Avatar
Default Weird Noise from Engine Bay HELP
I noticed a weird noise on my camaro ss 1999 after fixing a coolant leak directly on top of water pump. Also, I washed the engine bay with simple green and hosed it off. This is what it sounds like now! I hear it from the water pump pulley ( it wobbles a bit). Let me know what you guys think!
http://www.youtube.com/watch?v=xJgptyRcdq4
Old Nov 21, 2011 | 02:15 AM
Crimsonnaire's Avatar
One of the pulleys is shot (most likely water pump). That sound is the pulley or shaft wobbling. My water pump pulley also wobbled when it wore out, but only in my hand. It didn't wobble when it was installed because of the belt's tention pushing it up to one side. It looks like you've got other parts loose behind the pulley. Best change it ASAP to avoid unwanted problems such as possibility of the impeller shaft disconnecting from the pulley (thus stopping coolant flow) or having the coolant start to leak when you're out in the middle of nowhere.
Old Nov 22, 2011 | 10:38 PM
14k's Avatar
14k
thats the water pump!! trust me i know. i procrastinated too long and on my way to work it finally gave out and slung coolant all over my engine bay and drained on the ground. fix it ASAP!
Old Nov 25, 2011 | 12:18 PM
johnny89345's Avatar
This noise came on my 99 ss about three days before my pump pretty much exploded in the middle of wyndanch. Replace the pump ASAP.
Old Nov 27, 2011 | 04:42 AM
I replaced the WP and all is good
Old Nov 30, 2011 | 02:11 PM
Stang-Slayer's Avatar
Win!!!
Originally Posted by camaro1999ss818
i replaced the wp and all is good
