Oil Leak
If you suspect the rear main, put the car up on stands, and remove the inspection cover, take a good bright light, and look up at the rear main, if you see any oil above it, then the leak is coming from up top, valley cover gasket, oil pressure sender, busted PCV hose. If the oil is only below the seal then its leaking. If you see oil on the sides of the cover right where the pan meets, then look up higher on the engine, if oil is running down its coming from the valve cover, or filter housing, or bypass cap, if not and its just around where the pan meets the block then it is the pan gasket. Hope this helps
