Sponsored by: CARiD
ASR problem
Old Dec 19, 2011 | 02:48 PM
99camaro5.7's Avatar
Unhappy ASR problem
OK so I just bought my 99 z28 a few months back and i've noticed that if i press the asr button nothing happens, no lights come on to let me know the system is off. I've done one burnout which it did great in first but as soon as i shifted to second it completely stopped spinning. Just before i did the burnout i pushed the button thinking maybe i just have a blown indicator light for the system being off. Something to note is that the service vehicle soon/abs/and brake lights are on. I was wondering that if because those lights are on will that automatically shut off the traction control system?
Old Dec 19, 2011 | 03:47 PM
777's Avatar
777
Sounds to me that someone put a 3-channel rear-end in your 4-channel car (that would cause every one of your lights and explain your issue). Look at the rear axle and see if it has a sensor on both ends behind the brakes. If it does make sure they are plugged in good, if that doesn't work check the fuses.
