Car wont start
Now I just have to figure out what where and why so I dont get stranded again
ideas?
if you're getting the single click, you first need to check ALL of your connections. in particular, i've had issues in the past with the positive terminal on the gm sidepost batteries. take it off of the battery, and peel the red cover back. chances are good that you'll find a lot of corrosion in there. this has been the most common thing i find, next to bad starters.
i've rarely found bad grounds on gm's, but strongly recommend you check them anyway. if they're all good, it really sounds like you're looking at a starter.
i like the side terminal idea....but you're right. between corrosion, and them coming loose so easily, they can be a nightmare. especially on setups like cadillacs where they stack multiple terminal ends on the positive side.
i used to work doing radio installs for fleets, and we often needed to convert to those.
