Several Problems here, hoping for some ideas.
1. My oil pressure is a little on the low side i believe. I know it could be the pressure sending unit. But I just want to see what other people think about it. Warm idle the pressure drops down to 20-25 PSI. It goes up as rpm goes up and it also seems to bounce as well.
2. I believe I have some rear end whine, but I was wondering if it could possibly be wheel bearings. Not very much at lower speeds, but once i hit up around 50 it gets to be a steady whirring noise.
3. Car bounces going down the freeway. I don't expect a cadillac, but it just feels like the rear end is hopping. Wondering if it could be due to a bad torque arm mount rubber bushing thing?
4. When the car does a cold start, it makes a weird noise. I don't think it is piston slap, and i'm not sure if it did it before i put on my manual belt tensioner. So that could be the issue?
Thank you to anyone who has encountered these and might be able to help me out.
2. Same as my car, I'm gonna change the gear oil and try that first, then wheel bearings would be next.
3. What shocks? Stock? Lowered? Plenty of good deals for shock/spring combos out there that will perform better in every aspect and even ride better than stock.
4. Not sure on that one, belt/pulley squeak or power steering maybe? Is it straining or pulsing with RPM? I put a new belt on my car and my pulsing squeak went away, but now its come back, going to try to regrease a few idler pulleys and take off the AC belt to try to narrow it down, or my PS pump or rack.
Stock shocks and all, got some new ones coming hopefully.
i got a new belt and manual tensioner. maybe i should try greasing pulleys and all.
I took my belt off and spun the pulleys, they should be smooth as glass.
2 of my idlers sounded like crunching rocks lol.
Going to try to repack them with grease.
Sounds like its coming from the right idler/PS/Waterpump area, but right in the middle so I can't ID it lol.
Car has new belt, AC belt is off.
