Sponsored by: CARiD
vibration when decelerating
Old Jan 24, 2012 | 11:16 AM
sgranch's Avatar
Default vibration when decelerating
Hi, just bought a 2001 camaro and it test drove fine. Took it about 300 miles and started noticing a bad vibration around 60mph when decelerating or at a constant speed. If I get on the gas, it goes away, but the faster I get up to, the worse the vibration is on deceleration. Replaced the U joints and that didn't fix it. It's not the tires. Any ideas?
Old Jan 24, 2012 | 04:29 PM
KyleW707's Avatar
I have the same problem and no one can pinpoint it. Does it vibrate at higher rpms when you have it in park also?
Old Jan 24, 2012 | 06:15 PM
nascarnate326's Avatar
Same issue here. Mine is ok until about 70-75. At 95 it feels horrible.
Old Jan 25, 2012 | 09:41 AM
wssix99's Avatar
Save the manuals!
Is this only when decelerating? Does this only happen when you are on the brakes or does it also do it when you are coasting?
Old Jan 25, 2012 | 05:44 PM
sgranch's Avatar
It vibrates when letting off the gas, or staying at a constant speed above 2000 rpm. There's vibration under that speed but when it hits 2000 it gets much worse. Braking doesn't increase or decrease the vibration. I replaced U joints, driveshaft, and wheel bearings. Put it up on jacks and took the wheels off, same vibration. Took the driveshaft off, same vibration. It vibrates in park and neutral.
Old Jan 25, 2012 | 05:54 PM
sgranch's Avatar
correction, up on the jacks there is a vibration in park and neutral, but its not nearly as bad as the vibration in drive.(same RPMs)
