Sponsored by: CARiD
help me troubleshoot
Old Feb 4, 2012 | 10:18 AM
chejos13ls1's Avatar
Default help me troubleshoot
every time i try to start the car up in the morning,the revs go to about 3k and pretty much stays like that unless i turn the engine off or disconnect the battery,also seems to be that once the engine goes up to temperature the problem disappears,it all started when i wanted to use the car after a 2 week shutdown,it was working fine before that....i checked for loose connectors and vaccum hoses,but there's nothing loose ,also im on a speed density tune thanks
Old Feb 4, 2012 | 10:23 AM
Intimidator02SS's Avatar
Are you disconnecting the battery while its running?
You didn't find ANY vacuum leaks? Do you have access to a scanner? Do you have any codes?
Old Feb 4, 2012 | 12:41 PM
my bad, i mean turn the ignition off ,then disconect the battery,kinda like a reset
Old Feb 4, 2012 | 04:33 PM
jam01's Avatar
iac could be bad, or the tps.
