Sponsored by: CARiD
Need Help 350T spraying fluid....
Old Feb 5, 2012 | 09:19 PM
Ham10's Avatar
Default Need Help 350T spraying fluid....
ok guys just bought this car a few days ago has an LS6 backed by a 350 turbo trany with 2500 stall. car runs and drives fine, but when getting on it or leaving the hole under a load the trany sprays fluid on header and causing smoke everywhere which looks like sh*%. is there something i can do to fix this any suggestion would be great!!! thanks
Old Feb 5, 2012 | 09:45 PM
RARON455's Avatar
check the lines that are running from the trans to the cooler, look for a leak, or a busted line or fitting. that may be where the problem is coming from, also give the dipstick tube a good look. that could be another source. I would bet its one of those thats causing the problem. Hope this helps.
Old Feb 5, 2012 | 09:48 PM
Ham10's Avatar
thanks ill check it out...
Old Feb 16, 2012 | 07:45 PM
gofasterdammit's Avatar
The transmission might be venting. Look on top of the transmission to see if its wet. There is a vent tube there. If the pump is cross feeding into the vent port it will blow out the vent under load. If it is you need to go to a tranny shop and have the pump replaced. Ive seen this quite a few times at my tranny shop.
