Not Reading Bank 2 O2 Sensor
On to the sensor. Bank 1 fluctuates like it should. However bank 2 (passenger) sits at 430-450mv no matter what. Picked up a new vette sensor 13111 assuming it was bad. Got home and changed it out. Still done the same thing.
Unplugged it, no change. Unplugged bank 1 to test and it did what bank 2 is doing so I plugged it back in and got to looking for burned/pinched wires on bank 2 to no avail. i did unplug the extension and bypassed it since the vette sensor had a longer cable and it still read .430-.450 so i just put the old sensor back in. The fuses are good so what would cause this?? I'm hoping it's not a bad computer since it's not wanting to read the sensor.
Any help would be appreciated!!
https://ls1tech.com/forums/pcm-diagn...0mv-450mv.html
You can thank me later
