alternator wire I am replacing the alternator on my 99 z28 and I see that there is a ground wire on the back held on with a 13mm nut and there is a connector with ONLY ONE wire going into it. I thought maybe the wires had been cut or pulled out but upon further inspection I cant find any other wires and also there are no connector pins inside the connector other than the one wire. Can someone please enlighten me because I'm a little confused. Thank You |
No there is only supposed to be one wire. I believe it is called the exciter wire, when I removed my alternator once I tore the wire out of the connector. |
Yep .... same thing that I found on my '99 Z28. I had to replace the pigtail that connects to the altenator. |
If your alternator ONLY has a ground and the battery connector wires then someone may have replaced the alternator with a 'single-wire' replacement that does not use the multi-pin exciter and voltage sense wires common to most all OEM alternators. |
Originally Posted by mattmatt350
(Post 15976441)
Originally Posted by CharlieB53
(Post 15988566)
If your alternator ONLY has a ground and the battery connector wires then someone may have replaced the alternator with a 'single-wire' replacement that does not use the multi-pin exciter and voltage sense wires common to most all OEM alternators. One-wire units are "excited" by rpm rather than battery voltage. They only require one wire, and that wire is used for charge output (not ground, not exciter). |
© 2024 MH Sub I, LLC dba Internet Brands
