Sponsored by: CARiD
HVAC diagnosis
Old Feb 23, 2012 | 01:36 PM
Double J's Avatar
Default HVAC diagnosis
Had a new LS3 Motor installed in my 00 Camaro, The AC is not working, I turn the switch-not hearing the compressor turn on, I can hear air rushing through the vents but not blowing through Initially the plug that connects to the compressor was not connected but I plugged it in and same results. Any heads up as to what the issue may be would help b4 I go to AC Mechanic-The AC blew cold and worked fine b4 the engine swap.
THANKS IN ADVANCE
Old Feb 24, 2012 | 07:11 PM
nomasterase's Avatar
need a lil more info than that. is there any freon in the system now? was it discharged during the engine swap?
Old Feb 25, 2012 | 12:49 PM
Double J's Avatar
Hmmm good point I have to ask the engine builder, but would that effect whether the compressor would turn on?
Old Feb 25, 2012 | 01:34 PM
Yes if there's no freon the pressure sensors will detect that and disable the compressor clutch to keep from damaging the compressor
Old Feb 27, 2012 | 08:34 AM
CamaroSS27's Avatar
ya sounds like its got no freon to me
Old Feb 27, 2012 | 07:47 PM
Double J's Avatar
Thank you guys,that would relieve stress of having to buy new compressor$$$
Evacuate n recharge right ?
Old Feb 28, 2012 | 07:41 AM
Yes evac and recharge and if you wanna go above and beyond replace the accumulator and orifice tube
