Sponsored by: CARiD
Finally fixed odd brake light issue
Old Mar 5, 2012 | 10:12 PM
69gto96z's Avatar
Default Finally fixed odd brake light issue
I have been having problems in the past few years of my driver side brake light working when it wants to. Half the time it would work, half the time it wouldn't. Both other brake lights worked just fine, and all blinkers worked just fine. I traced the wires multiple times and they were fine, all grounds were good, replaced the bulbs too. Today I went down to autozone, and bought 2 new sockets for the driver side brake light. Wired em in and bam, all was good. Just a heads up for anybody who might be having an issue similar to this. There was a little bit of corrosion in the original sockets, so I guess the bulb just couldn't make a solid connection anymore.
Old Mar 6, 2012 | 10:00 AM
wssix99's Avatar
Save the manuals!
Another option is to replace just the socket inserts, which can be had for less than $1 each from Mouser Electronics. (Less expensive and no socket splicing required.)
Old Mar 6, 2012 | 02:31 PM
runtwrestlin's Avatar
That's kinda like when you ask someone for directions, and they just say "North." Perfectly applicable, but a little more specificity please?? I just went to their website and am rather as to which options I need to select to get to the right ones
Old Mar 6, 2012 | 06:34 PM
wssix99's Avatar
Save the manuals!
Just have to do a search... https://ls1tech.com/forums/general-m...t-gaskets.html
All the info and resources needed to re-work the rear sockets are in the thread above.
Old Mar 7, 2012 | 11:01 AM
Oh...search the forums......yea... I meant on Mouser Electronics website...but your instruction was far better than what I asked for. Thank you sir (once again)!
Old Mar 7, 2012 | 11:20 AM
wssix99's Avatar
Save the manuals!
Ah - Mouser has tons of components but if you type in the Delphi part number, it will take you straight to the part. Often, you'll see two options listed. One is for the part in bulk packaging to be used by automated machines. The other one is for single parts. Just select the part option that shows an available 1 qty and it will be the one you want.
Old Mar 11, 2012 | 02:57 PM
69gto96z's Avatar
I had no idea they even made those, definitely a better route to go than splicing in new ones.
