Sponsored by: CARiD
PCM ECU Wiring Problems !!!
Old Mar 10, 2012 | 03:47 PM
Reaperchild's Avatar
Question PCM ECU Wiring Problems !!!
Got my scanner to scan a SES CODE ... & SUPRISE !!
My Reader/Scanner cannot read my ECU/PCM !! (It Reads My Brothes 02 WS6 Perfectly Fine)
Q.
How do I start a proper diagnonsis to this problem & fix it effectively ?
How to Identify PCM functionality ?
What exactly am I looking to face up with this matter ?
Which ABS Fuses to Un-Plug After ABS Delete (Safety Only - Took 5 Out from under the hood already) ?
Any Optimistic threads & suggestions are more than welcome.
Recent Addons,
  • Tick MC
  • Solid Motor Mounts
  • ABS! & The Big ABS Connector (Removed)
  • Line Lock Installed
The Car resets its Trip with every startup since day 1 I got it, but even then, the scanner read my PCM.
Battery disconnected & replugged;
Service engine light came on after a few minutes.
Its really hard to know whats worng with the car when you cant talk to it
Old Mar 10, 2012 | 07:33 PM
chrysler kid's Avatar
My formula has the same problem. The cigarette lighter fuse was blown and surprisingly that controls the obd2 plug interface lol
Old Mar 11, 2012 | 03:29 AM
Kindly tell me you are not serious !! .. I had my wife kick my back side for being too late yesterday for a Cig fuse ... ill check it out & let you know ... if true ... it must be a stick y on PCM/ECU diagnosis.
Old Jan 24, 2013 | 06:31 AM
Damn right it was a damn fuse
