305 engine sputtering while driving, need help. (Updated 3/17)
It idles fine, but while trying to drive it, it starts to sputter and around 2k rpm it gets bad.
I have the timing set to factory specs. Could it be the distributor?
It also depends upon if you run manifold or ported vacuum to the vacuum advance also to when the timing is added.
Wanted you to disconnect it to see if the vacuum advance was causing a problem with the pick up coil harness inside the distributor.
Was kind of common back in the day.
Could there be a clog or no vent in the tank?
