Engine overheating, or not ??
i just bought a 98 Z28 Camaro (LS1) and i don't know if what is happening is normal or not.
at first the low coolant light warning turned on i called the previous owner and he said its totally fine and it will go off once the engine is cooled. turned off the car and started it after a while and the light was gone.
the same day I've noticed that the coolant temperature gets to 104 or 105 C and drops back to 75-80 C. it keeps doing that when i leave the car idling for like 5 minutes. when am driving though the temperature is always about 80 C.
when the A/C is on this never happens.
ANOTHER PROBLEM
the oil pressure is between 140 - 275 KPA (20-40 PSI) always. even when i floor it. it barely gets over 275 reaches 277 or so... sooo is that ok ??
and forgive me for my poor English.
thanx in advance
2. A steady temperature when you are driving is normal, the car is getting air flow through the cooling system. If it gets noticeably hotter when idling it could be an over heating issue, but not by much. I think if my conversions in my head are right you're only slightly above normal.
3. The oil pressure is normal expect when flooring it, around 20 psi no lower is okay at idle and it should be over 40 PSI when flooring it.
Have a proper oil change done on it, oil, filter, and check to see what oil has been run in it previously to use the same. If not use manufacture recommendations, any shop will know what to use if you don't tell them a preference. I suspect it is just over due for an oil change and the filter is done for. The oil pressure naturally runs low at idle though no worry.
Good luck.
Regardless; it is a very important part, especially in a hot climate. The sensor is there for a reason - to tell us when we are critically low on coolant. The sensor saved me from burning up my engine when I had a bad water pump that was pushing air in to the system. I highly recommend replacing the sensor.
When the A/C is on, the engine has to work harder, which will require more cooling capacity, so its no surprise that the coolant temperature goes up in this situation. A good thermostat should keep you around 100C all the time, no matter the condition.
If you are not in the red section of the gauge, you are OK. But this sounds a little low. What kind of oil are you using?
I'll change my thermostat tomorrow, people recommend 160 degrees.
Regarding the oil pressure, I just changed the oil and went for Mobil1 (10W-30). I've noticed a huge difference in the oil pressure, idling: 20 psi =138 KPA. 2200 rpm: 37-39 psi = 275 KPA. My friends camaro is a bit higher also. But his engine is always cool coz he installed 160 F thermostat and programmed the fan to kick in earlier than stock. Soo I think cooling is somehow related to oil pressure maybe? Since the oil will be cooler. ???
Thank you again
Thank you again
I'd suggest telling your friends that you have a 160, (so they will be impressed) and then keep a 210 in the car so you won't burn as much gas.
i am pretty sure that my car is on the stock thermostats coz it is 110% stock
.. so i have to keep my engine cooled in every method possible
. + fuel is cheap around here. a full fuel tank will cost me around 5.000 B.D which is like 13-14 US$
is that normal oil pressure ?
driving 90 KM/H on 1600 RPM with 100% warmed up oil
http://postimage.org/image/kel36cm0n/
car stopped for traffic, in (D) my foot on the brake.
my friend does 275 KPA (40 PSI) when driving 80-90 KM/H . RPM= 1600
am doing 206-210 KPA (30 PSI).
and does 10 PSI make much difference (Not performance wise)
