Sponsored by: CARiD
clunk!?
Old Mar 31, 2012 | 03:07 PM
98gtp's Avatar
Default clunk!?
95 formula replaced trans bout 12k miles ago. Once in a while if I'm off the gas then step on it hard it will make a slight clunk once, basically just engaging. Wth is it? U joint? Trans mount?
Old Apr 1, 2012 | 01:39 AM
camaroboy14's Avatar
Had the same thing happen with my 94z28 it what a trans mount ..
Old Apr 1, 2012 | 03:34 AM
NicB's Avatar
could be several things. trans mount, torque arm, bad bushings in rear suspension. jack up your car and just look around. im sure youll see something that looks out of place
Old Apr 2, 2012 | 09:31 PM
98gtp's Avatar
Did you notice more vibration with the poly mount? Do you think it caused alot of dmg to trans?
Old Apr 2, 2012 | 10:13 PM
jarheadtex's Avatar
stock PHB twisting?
