Headlight Level/Travel - Help
My headlights did the jack hammer crap so I went to top solutions and got 2 brass gears and put them in. Lights go up and down perfect except one light is going up higher then the other... When I have them up my passenger headlight is more pointing to the ground as the beam is focused on the ground and not farther in-front of me.. "No the headlight it self does not need to be realigned", it has to do with the motor/arm to let it raise higher or something as my driver side like mentioned comes up higher and I can definitely tell when sitting in the car and looking at the tops of the lights, I used to be able to see both of them when i sit up high enough but now only drivers because of the issue im having. So if anyone knows how to adjust those id appreciate it THANKS!
